Old 03-01-2014, 08:45 PM   #1
d.j. moordigian
d.j. moordigian's Avatar
Default Restoration Qs...28-29 hub caps
I'm having some difficulty understanding, in the Judging Standards,
the time lines for the specific hub caps and the shapes of those caps.
1.
I know exactly what the 1st. style looks like, but I don't understand
the note under the photo and the drawing note.....they don't match.
2.
The 2nd. style is also the same problem! Also, the photo of the cap
"looks" like the surface were the "Ford" in script is flat.
3.
The 3rd. is also the same problem, but not that far off. Also, the photo
of the 3rd. style "Ford" script looks convex.....like the drawing.
Now, the drawing for the 2nd. and 3rd. look the same, except for
the bases,....the 2nd. has a slightly "fatter" base?
My car is an Mid-August 1928,...do I use the 1st style or the 2nd, back
to the time line again.
If I use the 2nd style, I would like to see photos of the 2nd and 3rd
styles, side by side, also good top views,...so I can figure out which
one is which, when I'm looking at a swap meet.
I do and appreciate all the hard work that both JSC do! I need some
help here with the 2nd style cap,........thank you. This is in the revised
2011, 22-4.
Dudley
d.j. moordigian is offline   Reply With Quote
