Old 12-19-2013, 08:24 PM   #1
LopezCarguy
LopezCarguy's Avatar
Default Belt rail on Cabriolet
I have removed belt rail to be re done, under belt rail was a black tar paper type material, I would think in this day and age a black silicone caulk would seal better....any thoughts...Dick
LopezCarguy is offline   Reply With Quote
Old 12-19-2013, 08:46 PM   #2
Kevin in NJ
Default Re: Belt rail on Cabriolet
Just anti squeak. Basically a cloth tape. Way too easy to get some new tape and use it. No mess, just stick it on and you are done.
Old 12-19-2013, 09:09 PM   #3
Marco Tahtaras
Marco Tahtaras's Avatar
It's best to avoid ANY caulking that contains silicone. It promotes corrosion on steel. If you did feel the need to seal it, dum-dum strip caulking would be the best and most appropriate material for that type of application in my opinion.
I would have expected friction tape. In either case it's primarily an anti-squeak. Any type of caulking alone would be insufficient for that purpose.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-20-2013, 06:42 PM   #4
LopezCarguy
Thank you for suggestions, I will use some type of cloth tape, just finished the wood work and am ready to start mounting with new screw/bolts....it is a exact copy of original wood and it fits perfectly...but is solid white oak...going to be nice to tack to when I reach that point, if I live long enough...ha ha Dick
