Old 11-07-2013, 05:47 PM   #1
Gold Digger
Default Speedometer lube
When taking the speedometer apart to clean and put new numbers on what kind of oil or grease should I use to lube the shaves and gears with? One of my speedometers bound up and twisted the cable into on a Stewart Warner oval face.
Gold Digger is offline   Reply With Quote
Old 11-07-2013, 06:47 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Speedometer lube
Lubriplate Multi Purpose Lithium Grease
Old 11-07-2013, 08:05 PM   #3
Steve Miller
Steve Miller's Avatar
Is powdered graphite ok?
Thanks
Steve Miller is offline   Reply With Quote
Old 11-07-2013, 09:21 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I squirt some oil down the outside housing and then push the cable in as it runs through some grease in the palm of my hand. Smooth as silk 12 years later.
Old 11-08-2013, 12:32 AM   #5
Mike V. Florida
Do you have any suggestions in the inside of the speedo?
Old 11-08-2013, 02:45 AM   #6
Tom Wesenberg
I use a couple drops of oil and some grease on the bevel gears under the oval plate, and a drop of oil on each of the shaft bushings inside the housing.
I haven't worked on any round speedometers.
Old 11-08-2013, 07:16 AM   #7
lindy williams
Grasp the base of the speedo where the cable goes in with your thumb and forefinger and turn the shaft. The shaft should turn easily, if not, you will twist off another cable.
Soak light oil into the shaft bushings with speedo upside down. Not too much oil.
lindy williams is offline   Reply With Quote
