I am setting up the rear fender welting and do not have the luxury of original stuff for a pattern.
Keep in mind I have a 31 cabriolet which is the same as coupe roadster. I am using the lacquer cloth type as opposed to the vinyl. How is the sharp bend where the apron goes under the body handled? I know there needs to be a cut in the webbing to the bottom of the bead. What would be the correct cut shape? The rest appears to be straight forward. Do I need to make any other relief cuts? Are there relief cuts for the apron bolts or holes? Thanks! |
