Old 06-13-2025, 08:20 AM   #1
Woodie1
Woodie1's Avatar
Default Generator Pulley
I can't tell if this is a thread on pulley or a keyed pulley. Can somneone tell me?
Woodie1 is offline   Reply With Quote
Old 06-13-2025, 10:16 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Generator Pulley
Since there is no nut and no threads sticking out it should be a threaded pulley.
Old 06-13-2025, 10:20 AM   #3
hueyhoolihan
don't know for sure, but logic would tell me that if was threaded there would be some sort of hex arrangement welded to the front of the pulley but not the shaft so as to unthread it, otherwise a chain type wrench would be necessary, which is a possibility. and if it was was a friction fit i would need a puller to remove it.
not sure that keyed arrangement couldn't be common to both. as the key is just there to prevent rotation. it does nothing to hold a pulley on to its shaft AFAIK.
anyway, because i'm not seeing a nut, so i'd be looking in my garage for a puller of some sort.
i suspect others can be more definitive.
hueyhoolihan is offline   Reply With Quote
Old 06-13-2025, 10:59 AM   #4
petehoovie
petehoovie's Avatar
Old 06-13-2025, 11:00 AM   #5
glennpm
glennpm's Avatar
Disassemble the generator. Mount the armature in a vice protecting it with HDPE plastic such as a shampoo bottle or oil container, all of which are #2 plastics, etc. Use a strap wrench or an old fan belt with vice grips to unthread the pulley which you have sprayed with PB Blaster or the like ahead of time.
https://www.fordbarn.com/forum/showthread.php?t=35654
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 06-13-2025, 11:11 AM   #6
ndnchf
ndnchf's Avatar
Thread on. I restore a lot of these generators and see them often.
Restored Ford 6 & 12 volt generators
ndnchf is offline   Reply With Quote
Old 06-13-2025, 11:36 AM   #7
Woodie1
Woodie1's Avatar
Thanks for the help. I will try the thread off idea.
