Old 10-03-2024, 07:47 AM   #1
50Trucking
50Trucking's Avatar
Default Title for car where engines are swapped
I am in Florida. I just purchased an A model that was under restoration when the owner died. The car came with a title from the seller's widow. The deceased had the engine completely rebuilt by a reputable builder.
The car is not a good candidate to be restored to a very nice car however it can be reassembled into a good driver, that will be presentable.
I have an good engine that I purchased from a guy that bought an A and just used the body for a Hot Rod and sold off the drivetrain parts.
I want to put the used engine in the car and save the rebuilt engine for another project.
This brings me to the questions. When I change the engine, the serial number on the Title will not match the car.
When I put the engine in another car I am building from spare parts and pieces, which has not been titled "Bill of Sale only" The engine number will show up in the Florida records as belonging to the other car.
What do I do about this? Do I contact DMV and tell them I am changing engines and need a new title or what?
Then what do I do about the other car when I get it put together and ready to title it.
Should I grind off the numbers on the two engines and swap the engine numbers. Can this be done.
This has to come up in the A model World all the time as engines are replaced frequently but I have never been in this situation.
Your help in steering me in the right direction is appreciated.
50Trucking is offline   Reply With Quote
Old 10-03-2024, 08:41 AM   #2
JayJay
Default Re: Title for car where engines are swapped
Yes, grinding the old number off and stamping on a new number can be and is often done. Private rebuilders and “production” rebuilders in the past did it.
Legally, I cannot and will not comment. Ethically, you are stamping a number of your choice into a hunk of iron that you own. You are not representing anything other than that engine with that number is installed in the vehicle with that title. I personally have no issue with that. I’d suggest that you grind all numbers, though, so you don’t have two blocks displaying the same number.
This issue has been extensively discussed on this forum. You can get the proper Model A stamps from restostamps.com, or they occasionally come up on EBay.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 10-03-2024, 08:56 AM   #3
ronn
many on here will say no. I would do that or place a vin tag on the firewall with the title number, for inspection. Florida does inspect.
Old 10-03-2024, 08:59 AM   #4
alexiskai
alexiskai's Avatar
I'm doing something similar in NC. The procedure you go through here is for an "incorrect title." Basically you say "I have the title for this car, but something on the title is incorrect and I need an updated, corrected title." The NC title manual published by DMV has a specific procedure for updating the VIN when the VIN is on the motor. You have to produce documentation showing what happened to the old motor with the old VIN (you took it out and you still have it) and where you got the new motor with the new VIN (bill of sale from the guy who sold it to you). You submit the documentation and hopefully they issue a new title with the new VIN.
You'd have to figure out the equivalent of this process for Florida.
Old 10-03-2024, 09:08 AM   #5
ronn
with that said Alex............it can become a can of "worms"
Old 10-03-2024, 09:35 AM   #6
WHN
If the engine number on the car you just purchased matches the frame number, I would leave it in that car. Matching numbers are a real plus! Not many left.
As RONN said. You could be opening a real can of worms.
Old 10-03-2024, 10:44 AM   #7
LeonardS
My engine that matches my title, had a crack in it when I tried to rebuild it. I rebuilt a different engine, but I kept the original block which will go with the car when/if I ever sell it.
LeonardS is offline   Reply With Quote
Old 10-03-2024, 10:52 AM   #8
rackops
rackops's Avatar
Maybe a dumb question, but why not just apply for a 17-digit VIN?
One of my cars came from a nation that required 100% 17-digit VINs, so it had one assigned. I can swap out the engine every day of the week and no one will care because the VIN won't change.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" and a 1931 Victoria "Katie"
Former owner, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 10-03-2024, 10:56 AM   #9
Bob C
Does your title match the number on the frame??
Bob C is online now   Reply With Quote
Old 10-03-2024, 11:13 AM   #10
Benson
Question:
Suppose I buy an engine from a Hot Rodder. He keeps the title and gets a new title for his hot rod using the engine number on the title.
Now I have an engine with "his engine number" on it since he has the title.
Now I put the engine in my car or one that I just built from parts.
DMV titles it with the engine that I have.
Who gets to keep their car if the DMV notices the numbers are the same?
Old 10-03-2024, 11:19 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
See if your DMV will check if the number is registered, I have asked and found out that one engine I have has a “open” number, another car that just had a bill of sale they check the national database to see if that number belongs to another vehicle.
The first person to register with that number probably gets it.
Old 10-03-2024, 11:19 AM   #12
Bob Johnson
Bob Johnson's Avatar
Please note that if you file or grind off the original engine number some DMVs will notice that and you may have problems. Some DMVs will require that you show them the number on the frame. If it does not match the engine number you will have a problem.
Bob
Bob Johnson is offline   Reply With Quote
Old 10-03-2024, 12:25 PM   #13
shew01
shew01's Avatar
I recently went to the Virginia DMV to ask about titles that don’t match the engine, and I was told the following by a “worker bee” and a manager. Neither would give me anything in writing. So, if I purchase a car whose engine number does not match the title, I would expect the Virginia DMV to give me a hard time about it, and I would expect the DMV person that I end up dealing with at that time to have yet another interpretation of the law. Consequently, I’ve passed up several potential Model A purchases because of the foolishness below.
- After purchase, the DMV will research the car’s engine number on the title and the engine number in the car to see if they can get any correlation
- The DMV will not research engine numbers on title and in car in advance
- The DMV cannot guarantee a title transfer will take place
- The title should always go with the engine; I didn’t mention that the frame should have the engine number on it too—sometimes that rusts away and cannot be read anyway
- The manager suggested I talk with a lawyer or contact Facebook groups—this is simply “amazing” advice from a presumed DMV expert
- The manager told me if the engine number do not match in Virginia, the DMV considers it a crime
Old 10-03-2024, 01:20 PM   #14
rfitzpatrick
It's never a crime to restore/drive the Model A -
rfitzpatrick is offline   Reply With Quote
Old 10-03-2024, 01:38 PM   #15
John Gibson
John Gibson's Avatar
I don’t know about Model A & T engines but no flathead V8 engine in the 1930’s had a serial number stamped on it. Early Ford’s had the serial number stamped into the drivers side frame rail in three different locations. The original transmission for that frame would have carried the same serial number as the frame.
John Gibson is offline   Reply With Quote
Old 10-03-2024, 03:51 PM   #16
ModelA29
ModelA29's Avatar
Get the state to assign a VIN. Just tell them the engine in the car is junk so you need to replace it.
Assigned VINs on anything from the 60s or newer are value killers. On the A it doesn't seem to matter.
People talk of matching numbers. I'm in the realm of neat but who cares it's not something worth lifting the body to see if it's true.
My car has an assigned VIN so I'm able to swap engines at will.
ModelA29 is offline   Reply With Quote
Old 10-03-2024, 03:56 PM   #17
Ed in Maine
50Trucking, I think you are going to be OK with this car. I live in Florida and wanted to purchase a Model A that had a title that was from another state and a title number that did not match the engine that was in the car. The owner had passed away. What he had done was move the car from another state where the car was restored, engine changed, but continued to renew the old registration by just sending the paperwork back to the DMV with payment. Therefore, I am purchasing a car where the paper work does not match the car I am purchasing! Florida has form that reflects a problem with the VIN, that the car has been inspected by a Florida DMV agent and he certifies that the car is as described by make, model and color and that the seller has been checked out and found to be correct. The agent actually goes to the location where the car is garaged. Go to the DMV and talk with them and get this form filled out, and arrange to have the car inspected. Good luck, Ed
Old 10-03-2024, 03:59 PM   #18
ModelA29
ModelA29's Avatar
The serial number on the T & A engines WAS the serial number of the car. The B engine still had the serial number pad but the actual serial number was stamped onto the cast in pad on the top of the flywheel housing. The V8 flathead also had the serial number on the flywheel housing.
Old 10-03-2024, 05:26 PM   #19
Charlie Stephens
Minor correction. The V8 serial number was on a pad on the transmission case and not the flywheel housing (in addition to other locations).
Charlie Stephens
Old 10-03-2024, 05:49 PM   #20
Charlie Stephens
The last thing I would do, or suggest someone else do, would be to grind off the old serial number and stamp in a new one. To the best of my understanding (I haven't had reason to research it) it is against Federal law to alter a VIN (serial) number. Your next problem would be with your state DMV when they looked at the car and said "this has been altered, they must be trying to hide something". The numbers were stamped into an "as cast " pad which would not be the surface left by a grinder. The "font" of the numbers was also unique (but they are available). At that point the DMV would probably remove the body and look at the serial number stamped into the frame (at your expense). If the vehicle had been stolen sometime in its life it would be returned to the rightful owner.
I encountered a similar problem in 1971 on my '31 RDPU. I wanted to change engines and have the paperwork revised to match the new engine serial number, which is what was done by the DMV for many years. I was told the policy at the time was to no longer register by the engine number but to assign a number and attach a plate to the door jam (see attached photo with a couple of blanked out digits) A plate with the same number was also hidden elsewhere on the chassis. Call our DMV and see what they recommend.
Charlie Stephens
