Can it be positively identified?
Is it a Generator or an Alternator on my 1939 Ford] Convertible with a replaced flat head engine. The engine is a 1947 or '48, 100HP, 59A-B, replacement with 12Volt, Positive Ground. There are no markings on it or evidence of tags removed. Previous owner has gone on to the Big Junkyard in the Sky with the sign that says "Take what you need!" Thanks y'all!
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems!" ROGER, WILCO, OUT! |
Looks like a generator.Is there a voltage regulator on the firewall?
Based on the middle photo, it looks like a generator due to the length of it.
The "power gen" (generator/alternator look alike) is shorter and somewhat fatter. If you have a voltage regulator on the fire wall, would just about confirm it to be a generator.
IN GOD WE TRUST - SEMPER FIDELIS John ![]() |
Yes sir, there is a 12v Regulator on the wall.
#5 | |
![]() Quote:
Roger that Jayvee, a 12v Regulator is on the firewall. I measured the length and it is 8.5" from the back to the end of the pulley. Hope this finds you well my friend!
Simple test: An alternator will have power all the time to the output post. A generator will only have power there with the car running.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
#8 | |
![]() Quote:
No doubt about it, that it is Positive Ground. Follow the Red Wire from the post to the firewall. Follow the Black Negative wire to the Solenoid. What are you suggesting that I "should look into?"
Don't fix what ain't broken. I went with 12v positive ground for for quite a few years on my 36 Ford. terry
Are you referring to one of the two posts shown in this pic on the round black thing which may be a Generator or maybe an Alternator or are you referring to the battery posts?
#11 | |
![]() Quote:
Thanks I agree with you 110%!
#12 | |
![]() Quote:
The posts in your pic....but never mind. I can see the commutator and part of a brush through the opening in the housing. It's a generator for sure! Terry
#13 |
An alternator will bump your car to Touring A Class with all the hotrods for V8 Judging. Newc
#14 |
Not my Whitney conversion, you wouldn't know it was there unless I told you
#15 |
Depends on what you want or going for.
#16 | |
![]() Quote:
Terry Thanks I feel much more confident calling it a Generator now
#17 | |
![]() Quote:
#18 |
Cadillac….I loved the quote from Smokey Yunick. He has to be my favorite stock car celebrity! He could go a ways further on a tank of gas than anybody else one Sunday and he got inspected after the race. He was running a 2 inch fuel line!! Smokey correctly pointed out that his tank was within specs. NASCAR put a rule in the next day that limited the size of the fuel line…
