Steering Column Dash Bracket
I have a '28 RPU and it's dang tight in there (I guess the RPU is the tightest of them all). I could add some much needed space if I could raise the steering column up tight against the bottom of the dash (I did this in my '48 Willys and it really helped). Does anybody know of a bracket that will do this? I see brackets to lower it but nothing to raise it. I can't be the only person to have wanted to do this. The fact that it is attaching right against the bottom of the gas tank prevents much freelancing. I probably should mention that my fabrication skills and tools are limited.
