Old 11-18-2021, 02:16 PM   #1
Krylon32
Default 49-50 Merc intermediate bellhousing
I've been buying some 49/50 Merc stamped steel intermediate bell housings that I clean up and resell to my customers buying my T5 Kit if they can't find one. Today as I was loading them in my truck to take to the blasters I noticed one was about a 1/2 inch deeper than the others. Anyone know what this fits as it sure won't work with my kits. Thanks
Krylon32 is offline   Reply With Quote
Old 11-18-2021, 02:19 PM   #2
cas3
Default Re: 49-50 Merc intermediate bellhousing
6 cylinder blocks
Old 11-18-2021, 03:56 PM   #3
Krylon32
I have a couple 6 cylinder bell housings. They are the same depth as the V8 just with a different bolt pattern where they bolt to the block. This bell housing has the V8 bolt pattern.
Old 11-18-2021, 04:04 PM   #4
Lanny
Lanny's Avatar
Mac VP would probably know...
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is online now   Reply With Quote
Old 11-18-2021, 08:07 PM   #5
cas3
I sold the deeper version I had to a fella on the barn here that needed it for a 6. Never heard back from him, so I have to assume it fit. Different bolt pattern I believe, and about 1/2" deeper. There was a thread on here, his was damaged some how, last winter I believe
Old 11-19-2021, 09:42 AM   #6
rotorwrench
rotorwrench's Avatar
A deeper half bell may be for some other 8BA family application. Mercury used the same half bell from the 1949 intro through very early 1951 but they all used the same basic transmission. 337 Lincoln & truck are altogether different as well as Ford cars & commercials.
I'd figure it must be for an industrial application but I certainly don't know what that might be. I don't know of any other transmissions that match the Mercury stamped steel half bell mounting but have a longer intput shaft.
Old 11-19-2021, 10:34 AM   #7
Charlie ny
Hey VanPelt where are you ? I've got 2 of those extra deep housings, only dumb luck
kept me from using one when I put my '32 together.
Charlie ny
Old 11-19-2021, 10:48 AM   #8
19Fordy
19Fordy's Avatar
The 1949-51 Mercury Chassis Manual lists two separate bellhousing assemblies NOT used with with automatic transmissions. One part # is 8CM-6392 used in 1949-51 Mercs and then another with part # 1CM-6392 used in 1951 Mercs.
Part # AC 6392-D is also shown for use in 1952 Mercs with non-automatic transmissions.
Old 11-19-2021, 04:55 PM   #9
rotorwrench
The bell housing that came about for most of the 1951 Mercury production is a big full cast iron bell housing that is very similar to the ones used in 1952 & 53 in Ford and Mercury cars but they all had swing pedals. The 51 Mercs were till frame mounted.
Old 11-19-2021, 05:33 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
'51 Merc Full Cast Iron BELLHOUSING ....RARE RARE!
Click Links Below __
T5 W/TORQUE TUBE
