Old 09-30-2019, 10:36 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Spark Plug Connectors
I find there are two different lengths of spark plug connectors in the 1930-'31 configuration. Which is the correct one, or are booth authentic for the Model "A"?
Bob Bidonde
Old 09-30-2019, 10:45 AM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Spark Plug Connectors
It has been my understanding that the longer of the two is for the Model B as the distributor is a little taller. The B distributor is taller to make room for the advance mechanism. Please correct me if I'm incorrect.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 09-30-2019, 11:06 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
I always thought that the longer spark plug connectors were used on the model B . I think that length of spark plugs was the reason for different length connectors . The 3X spark plugs stand taller than the C4 and some other spark plugs . If a TOO short connector is used it will contact the distributor cap body . When the spark plug connector contacts and melts a spot on the distributor cap it can cause a short between number 4 and number 3 cylinders . I prefer the longer connectors because they can be used with shorter spark plugs, model B's and digfferent aftermarket heads with different spark plug spacing .
Old 09-30-2019, 11:14 AM   #4
Purdy Swoft
I also agree with every thing that The Master cylinder said in post number two . I type slow and The Master Cylinder had already posted before I got through typing . Sorry .
Old 09-30-2019, 11:35 AM   #5
Cape Codder
Cape Codder's Avatar
According to The Restoration Guidelines page 2-12 Revised 2011:
"The correct connectors from the distributor to spark plugs were stamped from 26 gauge bronze which had a copper color. From the beginning of production through May 1930 the connector ends were symmetrical (rather than offset). A new design was introduced in June 1930 in which the ends were offset (for more efficient use of bronze sheet stock). Both types were 3 1/8" from the center of the hole to the end of the prongs. The spark plug nut was round, knurled brass, 7/16" in diameter and 7/32" high."
Cape Codder is offline   Reply With Quote
Old 09-30-2019, 12:37 PM   #6
Bob Bidonde
A long time ago, Clem Clements asked me about the two different lengths of spark plug connectors, but I had no answer for him. While inventorying my stash of parts, I came across the variations in spark plug connectors, so Clem's question came to mind. Here's your answer Clem, several years later. Thanks Master Cylinder and Cape Codder for the info.
File Type: jpg Spark Plug Connector A & B Comparison.jpg (8.4 KB, 61 views)
Bob Bidonde
Old 09-30-2019, 12:44 PM   #7
JoeCB
JoeCB's Avatar
And every one of the repop connectors that I have seen are made of brass and not bronze. You can tell by the "yellowish" color.
Joe B
JoeCB is offline   Reply With Quote
Old 09-30-2019, 01:03 PM   #8
Joop
Joop's Avatar
Order them at A&L in Connecticut and you get the real ones.
Joop is offline   Reply With Quote
Old 09-30-2019, 01:45 PM   #9
Clem Clement
Clem Clement's Avatar
thanks Bob Bidonde!! I can sleep now!
Old 09-30-2019, 02:34 PM   #10
The Master Cylinder
Joe B
Snyder's sells both the brass and bronze.
The Master Cylinder
Old 10-01-2019, 08:04 PM   #11
Ronald
Ronald's Avatar
How about these found on my 1930 Tudor !
Ronald is offline   Reply With Quote
Old 10-03-2019, 06:32 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Ask before you order the parts.
I only use the correct bronze ones, as the brass is too soft and more likely to come out of place.
