Old 11-04-2018, 02:56 PM   #1
Mr. Ed
Default Adjustable lifters
We are in need of lifters for our project. Do adjustable lifters require special valves or do the stock valves work with them?
Thanks!
Mr. Ed
1951 F-1, 351W, C-4, Henry.
1993 Mustang 5.0 LX convertible, Sally.
2006 Jeep Grand Cherokee Laredo, Herman.
Mr. Ed is offline   Reply With Quote
Old 11-04-2018, 03:44 PM   #2
MAG
MAG's Avatar
Default Re: Adjustable lifters
They work fine with original valves.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 11-05-2018, 11:10 AM   #3
Mr. Ed
Thanks Mag.
Later!
Mr. Ed
Old 11-05-2018, 01:29 PM   #4
100IH
Some times the original type valve need to have the but end of the valve ground shorter because the adj. lifters are longer.
100IH is offline   Reply With Quote
Old 11-05-2018, 03:52 PM   #5
MAG
MAG's Avatar
"Some times the original type valve need to have the but end of the valve ground shorter because the adj. lifters are longer.[/QUOTE]"
The only time I have seen this is when the valve face has been ground to the point the valve should be replaced and/or the seat has been ground to the point a new seat should be installed.
