Adjustable lifters We are in need of lifters for our project. Do adjustable lifters require special valves or do the stock valves work with them?
Thanks! Mr. Ed |
Re: Adjustable lifters They work fine with original valves.
Re: Adjustable lifters Thanks Mag.
Later! Mr. Ed |
Re: Adjustable lifters Some times the original type valve need to have the but end of the valve ground shorter because the adj. lifters are longer.
Re: Adjustable lifters "Some times the original type valve need to have the but end of the valve ground shorter because the adj. lifters are longer.[/QUOTE]"
The only time I have seen this is when the valve face has been ground to the point the valve should be replaced and/or the seat has been ground to the point a new seat should be installed. |
