We'll, I'm afraid I may have screwed up and bought the wrong wheels... I know they're supposed to be 16", but what width?
Are you going for 100% originally? Other wise the rim width is related to the tire width you are wanting to run.
Yes trying for "as-original-as-possible" when it comes to the drivetrain. Bought a set of late '41's that are 4" at the bead at Iola. Got home and was checking EFV8's "Two Great Trucks" and the author doesn't go into detail about rims, but the Ford promotional materials reprinted there list 6" tires as standard.
#4 | |
![]() Quote:
Depends what your doing with the truck, restoring or hot rodding. I used 15in on mine, big an little combo. 195/75 15 in front and 235/75 15 in back. Using original rear end and tranny
with 3;54 gears and a Mitchell overdrive. Last edited by 41PICUP; 07-14-2017 at 05:26 PM. Reason: info |
This is what got me wondering. |
V8COOPMAN has it right. The 1941 Sales Manual lists 16" x 4" wheels. Stu
Stu McMillan Marmon-Herringtons |
6.00-16s WERE the standard tires issued on Fords with the 85 horse V8, all on 4"-wide wheels as late as '41. When the drop center shape changed slightly in '42, the 16" wheels went to 4-1/2" wide. DD
4"-4.5" you won't see a difference looking at them. If you want 5" then it's going to get pricey as hot rodders have driven the price up if you can find them.
Operators Manual Ford F series trucks p66.
6.00X16 4ply F1 6.00X16 6ply F1 6.50X16 6ply F1 F2 7.00X16 6ply F2
Works good Lasts long time |
