Old 04-22-2016, 01:25 PM   #1
Bill in SoCal
Bill in SoCal's Avatar
Default Seal Drip Rail Gutters on 30 Coupe
The pictures are of the drip rails on my 30 coupe. They are welded on and I am not going to remove them. I can straighten the gutter and push it back but there will still be a gap. What should I use to seal the gaps between the roof and the gutters (shown In the pictures)?
Bill in SoCal is offline   Reply With Quote
Old 04-22-2016, 01:30 PM   #2
Bruce_MO
Default Re: Seal Drip Rail Gutters on 30 Coupe
You could try "Seaming Compound". It's the stuff used to seal panels that have been spot-welded together (seams in trunks, etc.). You can prime and paint it just fine. I have some in a quart can that I bought long ago from an automotive paint supplier. I think you can also get it in a tube for a caulking gun. I think that Eastwood also has it.
Bruce_MO is offline   Reply With Quote
Old 04-22-2016, 02:14 PM   #3
crock
crock's Avatar
Silicone would work just fine. Can be painted also. Give it 24 hours to set up.
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 04-22-2016, 02:33 PM   #4
Mitch//pa
Bruce's idea sounds good ..
We use this seam sealer
Old 04-22-2016, 09:37 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Silicone promotes rust, as I learned from a windshield installer. Use what Mitch shows.
Old 04-23-2016, 06:46 AM   #6
Jwilli
Jwilli's Avatar
Mitch and Tom are giving good advise. Some silicone is not paintable.
Jwilli is offline   Reply With Quote
