I'm thinking of converting my 48 Ford to 12 volt. Can you buy a bracket that will take a GM 1 wire alternator without machine work. Why I want to go this route is if I should have to replace on the road I could go to any parts store and get a stock GM alternator 1 wire. thanks
Available from most suppliers. I got mine from these guys:
www.qualitypowerauto.com 31510 Yucaipa Blvd, Yucaipa, CA 92399 (909) 794-1600 This the link to the brackets: http://www.qualitypowerauto.com/item...n-Brackets.htm
Google "alternator bracket" "flathead". And simply convert a GM 3-wire to a 1-wire by pigtailing a small wire from the small #2 terminal to the alternator's main output terminal. The small #1 terminal is not connected. GM 3-wire alternators are much more common than the 1-wire only types.
Jack E/NJ |
Certified auto electric in Ohio, but re-think that GM alt they have a great Ford one wire with bracket for our application.
As Jack said.
You will probably have to find a smaller diameter pulley to run on a flathead .
"Came too close to dying to stop living now!" |
You could consider going with an L.D. Becker 12v alternator onversion. See attached pictures. He uses the front mounting bracket w/bearing from a stock Ford intake mount generator. This could be used with/without a fan mounted to front of pulley.
I like that L.D. Becker conversion.
You can get an alternator bracket from almost any place. Speedway, Summit, Jegs they all carry them. Check eBay. They seem to run in the $30-$50 range. |
