Reinstalling a metal 4 blade fan on a 1936 car, (had a 6V electric fan, pull type ) the fan I came up with when installed on the front of generator is to close to the radiator hoses. ( like a gap of only a 1/8" ) Need to know what is the correct length of hup/spool portion of the fan. I looked at search section of early V8 forum but did not come up with an answer, lot of info but not exact, thanks Bruce
The 35-36 book says the fan should be 15 1/2" dia, 1 3/4" deep.
Thank you, will check mine in morning, seems like between the two hub flanges that I have only about 3/4 to 1 ", will advise, Bruce
my 36 is close like that
Ford |
I found a 2" fan hub, that is measuring from back of hub ( generator end ) to back of nearest fan blade. The 2" is to long, the one I have measures 1 1/8" ( to close ). Need to know where the 1 3/4" measurement is taken from, Duece_Roadster, any idea. I believe if 2" is to long that the 1 3/4" would be correct, need to find one, any info or location would like to know, thanks Bruce
Hope this helps
Ford |
More
Ford |
This photo is of a 36 fan on the genorator. I am not sure we're to measure from but this should be right
Ford |
jacob smith, that is what I have now, to close for comfort, less than a 1/8" at closest point on upper point of radiator hose. Need fan that measures 1 3/4" duece Roadster says is in book. thanks for the photos, same way I measured, Bruce
33-36 is the same fan. The 37-39 has a 7/8" longer hub
Here are pics of the the 36 fan (first 3) and the later fan. Ed
#13 |
Here are the pics.
#14 |
Bruce, Here are the correct dimensions for a 35-36 passenger car fan (40-8620-A)
#15 |
So Don, since you are co author of the 35-36 book, is that a misprint on page 103?
#16 |
Deuce. The 1 3/4" dimension referenced in The 35/36 Book was an overall depth dimension from the base of the fan hub to the center fan rivet.
#17 |
What Don is showing here is the most critical dimension to have or know when making sure you have the correct fan that should give you the correct clearance. If it doesn't, then something else is located incorrectly, IMO.
#18 |
I think you have the correct fan Bruce,you might have been measuring from wrong place.give it a try!!!!!
DON P |
#19 |
Be sure your fan belt is not too long. With too long of a belt it can cause the clearance to be awfully close with the hoses.
#20 |
Thanks for clearing that up Don, I think your diagram in post 16 is what Bruce wanted to know.
