The Ford Barn
-   -   1936 Fan dimensions needed! (https://www.fordbarn.com/forum/showthread.php?t=180385)
Bruce in southern OH 10-15-2015 07:35 PM
Reinstalling a metal 4 blade fan on a 1936 car, (had a 6V electric fan, pull type ) the fan I came up with when installed on the front of generator is to close to the radiator hoses. ( like a gap of only a 1/8" ) Need to know what is the correct length of hup/spool portion of the fan. I looked at search section of early V8 forum but did not come up with an answer, lot of info but not exact, thanks Bruce
deuce_roadster 10-15-2015 07:48 PM
Re: 1936 Fan dimensions needed!
The 35-36 book says the fan should be 15 1/2" dia, 1 3/4" deep.
Bruce in southern OH 10-15-2015 08:30 PM
Thank you, will check mine in morning, seems like between the two hub flanges that I have only about 3/4 to 1 ", will advise, Bruce
jacob smith 10-16-2015 10:41 AM
my 36 is close like that
Bruce in southern OH 10-17-2015 03:12 PM
I found a 2" fan hub, that is measuring from back of hub ( generator end ) to back of nearest fan blade. The 2" is to long, the one I have measures 1 1/8" ( to close ). Need to know where the 1 3/4" measurement is taken from, Duece_Roadster, any idea. I believe if 2" is to long that the 1 3/4" would be correct, need to find one, any info or location would like to know, thanks Bruce
deuce_roadster 10-17-2015 03:20 PM
The V8 Club restoration book only has those dimensions and not how they were measured. I would expect it would be from the mounting flange out to the farthest point. I don't have a 35 or 36 (only 32,33,40) so have no direct experience. Hopefully 36 owners on this forum will chime in.
jacob smith 10-17-2015 05:07 PM
1 Attachment(s)
Hope this helps
jacob smith 10-17-2015 05:08 PM
1 Attachment(s)
More
jacob smith 10-17-2015 07:50 PM
This photo is of a 36 fan on the genorator. I am not sure we're to measure from but this should be right
Bruce in southern OH 10-17-2015 08:23 PM
jacob smith, that is what I have now, to close for comfort, less than a 1/8" at closest point on upper point of radiator hose. Need fan that measures 1 3/4" duece Roadster says is in book. thanks for the photos, same way I measured, Bruce
35fordtn 10-17-2015 08:25 PM
33-36 is the same fan. The 37-39 has a 7/8" longer hub
Ed Pitts 10-17-2015 08:58 PM
Here are pics of the the 36 fan (first 3) and the later fan. Ed
Ed Pitts 10-17-2015 09:00 PM
4 Attachment(s)
Here are the pics.
Don Rogers 10-17-2015 10:23 PM
1 Attachment(s)
Bruce, Here are the correct dimensions for a 35-36 passenger car fan (40-8620-A)
deuce_roadster 10-17-2015 11:55 PM
So Don, since you are co author of the 35-36 book, is that a misprint on page 103?
Don Rogers 10-18-2015 06:59 AM
1 Attachment(s)
Deuce. The 1 3/4" dimension referenced in The 35/36 Book was an overall depth dimension from the base of the fan hub to the center fan rivet.
JM 35 Sedan 10-18-2015 07:21 AM
What Don is showing here is the most critical dimension to have or know when making sure you have the correct fan that should give you the correct clearance. If it doesn't, then something else is located incorrectly, IMO.
Don 10-18-2015 07:55 AM
I think you have the correct fan Bruce,you might have been measuring from wrong place.give it a try!!!!!
35fordtn 10-18-2015 09:09 AM
Be sure your fan belt is not too long. With too long of a belt it can cause the clearance to be awfully close with the hoses.
deuce_roadster 10-18-2015 11:22 AM
Thanks for clearing that up Don, I think your diagram in post 16 is what Bruce wanted to know.
