Old 12-11-2014, 05:17 PM   #1
Rich Bowes
Rich Bowes's Avatar
Default Crank shaft bearings
How often should crankshaft bearings be checked. I have heard every 5000 miles. Is that correct?
Rich Bowes is offline   Reply With Quote
Old 12-11-2014, 05:42 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Crank shaft bearings
Depends on different items such as the quality of babbitt used, whether it was peened in, and/or how much surface coverage the babbitt has to the journal pin.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-11-2014, 06:05 PM   #3
WestCoast
I make the first check at 5000 miles, if very little wear I let them go another 1000 miles or so on the second check, if excessive wear is found I check sooner the second time, around 3000 miles, like brent said, it depends on the babbit, how it was installed, who did the work, how car is driven and maintained
WestCoast is offline   Reply With Quote
Old 12-11-2014, 06:36 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
I've checked and adjusted the original babbit in my september 29 three times in 54 years .
Old 12-12-2014, 06:36 AM   #5
Patrick L.
Patrick L.'s Avatar
The engine in mine was done in 1961 and I tightened the mains a couple years ago[ the center and rear needed it], the rods were fine.
I guess I should add that I've done a few others over the years, I don't know the number of years or miles on them.
Only one needed the rods taken up a bit. All have needed a little help with the center and rear mains, nothing to the front.
Old 12-12-2014, 08:29 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I checked the main bearings once in 50,000 miles, and they were 0.002 to 0.004.
Bob Bidonde
Old 12-12-2014, 04:07 PM   #7
wensum
wensum's Avatar
Goodness! if one checked the main bearings every 5000 miles, for some us, that could be twice a year.
I drove my first Model A as daily transport and hard for a number of years without ever checking the mains and without any problems.
Keith
wensum is offline   Reply With Quote
Old 12-12-2014, 07:15 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
My Lord! If it's runnin' well & sounds good, leave the danged thing ALONE!!!
You'll wear out all the FASTENERS, just dickin' around with it.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-12-2014, 07:19 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Bill W.
Right, that's what wears out pants zippers.
Old 12-12-2014, 11:41 PM   #10
PC/SR
Well, I was going to give some sort of great insight, but I can't top Bill and Tom.
PC/SR is offline   Reply With Quote
Old 12-13-2014, 10:38 PM   #11
Cape Codder
Cape Codder's Avatar
I thought for sure we would have gotten some comments from our residence engine rebuilders. What would their recommendations be on the subject to their customers after having their engine rebuilt ?
Cape Codder is offline   Reply With Quote
Old 12-14-2014, 08:03 AM   #12
George Miller
George Miller's Avatar
When it is needed. There really is no answer to this question. Depends on how good the Babbitt was done how good the bearings were set. How fast you drive, plus a lot more.
I would just pay attention to the sounds of the engine when it is under load. If it knocks under load you may have a loose main. Also when you first start it after it has been setting for a while. The center main will knock when you first start it, on tell it gets oil if it is loose.
If you have to take the pan off for some reason, or you have a bad rear main leak check them then.
George Miller is offline   Reply With Quote
Old 12-15-2014, 03:18 PM   #13
Rich Bowes
Rich Bowes's Avatar
As some of you have suggested, the correct answer is: "if it ain't broke, don't fix it", or "don't go looking for trouble unless it comes knocking". Do I have this about right?
Old 12-15-2014, 04:24 PM   #14
whirnot
whirnot's Avatar
And make sure you do them with the engine still in the car, laying on your back without a hoist. It builds character.....
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-15-2014, 04:29 PM   #15
BlueSunoco
Oh man, and is that why sailors had buttons on their pants instead of zippers Not sure about today.............
BlueSunoco is offline   Reply With Quote
Old 12-15-2014, 05:06 PM   #16
Patrick L.
Patrick L.'s Avatar
It may be smooth and quiet with no load and not rear its ugly head until put under a load. Then it can be hard to hear but may be felt. Main bearing that is.
If it seems OK, it probably is. If for reason the pan ever comes off, then is a good time to check them.
