Old 10-20-2014, 07:25 PM   #1
FrankWest
FrankWest's Avatar
Default gear shift positions?
I still cannot find my owners manual and the awful service manual book is not help. Does the model B 1933 shift in the H pattern?
Where are the different settings?
FrankWest is offline   Reply With Quote
Old 10-20-2014, 07:29 PM   #2
tiquer
Default Re: gear shift positions?
yes
tiquer is offline   Reply With Quote
Old 10-20-2014, 08:47 PM   #3
DavidG
DavidG's Avatar
Yes. Beware that only the shift between second and third gears is synchronized. You must come to a complete stop before downshifting into first gear (and, of course, reverse). Also, when downshifting from third gear to first gear, you'll avoid gear clash if you first downshift into second gear immediately before downshifting into first gear.
Old 10-21-2014, 05:27 AM   #4
Vic Piano
Vic Piano's Avatar
As I understand it, the 'H' pattern for the shifter was introduced by Hupmobile (some time in the mid 1920's), and eventually adopted by all automobile manufacturers.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-21-2014, 03:42 PM   #5
Mart
Mart's Avatar
Frank, classic 3 speed H pattern.
Top left: Reverse.
Bottom left: First.
Top right: Second
Bottom right: Third.
There's also an imaginary fourth in mid air over on the right that you will keep trying to shift into before you realise that once in Third, that's the lot!
Mart.
Mart is online now   Reply With Quote
Old 10-21-2014, 04:29 PM   #6
CT AV8
CT AV8's Avatar
But you can double clutch into first gear without coming to a full stop.
CT AV8 is offline   Reply With Quote
Old 10-21-2014, 06:15 PM   #7
PeteVS
PeteVS's Avatar
Double clutching into first while moving is reserved solely for the driver who pays for the repairs.
