Old 08-06-2014, 09:38 PM   #1
Bruce of MN
Bruce of MN's Avatar
Default Install Trunk Lid Bumpers
I got some new rubber bumpers to replace the old petrified ones. I tried heating them up in hot tap water and using silicone lube spray, but they are too stiff and the sides of the body block good access with a screwdriver to work the base through the hole. Should I boil them to get them softer or any other suggestions?
Old 08-06-2014, 11:00 PM   #2
Steve Plucker
Default Re: Install Trunk Lid Bumpers
Lot's of WD-40...OR cut the rubber part down just so slightly so as it will fit into the hole eaiser.
Pluck
Old 08-07-2014, 07:42 AM   #3
Bruce of MN
Thanks, I'll try the WD40.
