Old 06-30-2014, 05:46 PM   #1
4tford
4tford's Avatar
Default another flathead starts up
This is the start up a couple of days ago of the 304 I built 6 months ago. Has one of Pete's 425 potvin cams.
4tford is offline   Reply With Quote
Old 06-30-2014, 06:34 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: another flathead starts up
Awesome!!
Bassman/NZ is offline   Reply With Quote
Old 06-30-2014, 06:50 PM   #3
Doug-F1
Doug-F1's Avatar
Sounds Good. That's a lot of work to get it to that point. Looking forward to see more of it.
Doug-F1 is offline   Reply With Quote
Old 06-30-2014, 07:11 PM   #4
4tford
4tford's Avatar
Doug-F1 if you are going to the Gimli Beach cruise in July stop by the booth and say Hi.
Old 06-30-2014, 09:44 PM   #5
AnthonyG
AnthonyG's Avatar
Feels / sounds great on that first fire up!!! Especially with open pipes!
Tony
Nomad
AnthonyG is offline   Reply With Quote
Old 07-01-2014, 06:47 AM   #6
JWL
NEVER allow a new engine build to idle at slow RPM.
JWL is offline   Reply With Quote
Old 07-01-2014, 07:12 AM   #7
scooder
I seem to recall that with a cam as aggressive as a 425, that the engine should never be idled low, even after the engine is all bedded in. Higher idle throws more oil at the camshaft and lifters. Can't remember where I heard it, but seems to make sence.
What's your thoughts on this John?
Would running the late Merc rods with the oil hole directed towards the cam help here? Would this allow the idle to be bought down?
I'm talking about an engine that's already been bedded in or run in or whatever it's called over there.
Martin.
scooder is offline   Reply With Quote
Old 07-01-2014, 07:44 AM   #8
1952henry
1952henry's Avatar
Wow! That sounds as hot as a whorehouse on dollar night!
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 07-01-2014, 09:59 AM   #9
4tford
4tford's Avatar
The vid is the only time engine has been run. Owner has already been advised to not run again until ready for complete break in.
Old 07-01-2014, 11:15 AM   #10
scooder
Broken in, was the phrase I was looking for, thanks.
Martin.
Old 07-01-2014, 06:52 PM   #11
4tford
4tford's Avatar
What rpm should the idle be set at on this engine???
Old 07-01-2014, 07:35 PM   #12
tiquer
Sounds great
tiquer is offline   Reply With Quote
Old 07-08-2014, 07:23 PM   #13
Doug-F1
Doug-F1's Avatar
4tford, no I'm unable to make Gimli Beach cruise this year.  If you could find the time when you get there have a Cold beverage for me.
Old 07-08-2014, 07:58 PM   #14
4tford
4tford's Avatar
will do that for sure. Steak and lobster night.
Old 07-10-2014, 02:05 PM   #15
Pomeroy41144
Pomeroy41144's Avatar
Pretty cool.
Pomeroy41144 is offline   Reply With Quote
