Does anyone reproduce the collar at the top of the steering column tube that the spark and gas rods travel in?
Tim Downtown, Ca |
Yep, look at any Model A parts catalog (Bert's, Bratton's, Snyder's, etc.) under steering and you will find it. It might be called a bushing.
Sorry Tom I was not more descriptive.....I was referring to the part welded to the tube with the notches pressed into it. Found out these are not made......Thanks.
Tim Downtown, Ca |
I would use a somewhat dull chisel to make the notches deeper. You'll have to hold a heavy steel plate against the backside while doing this, or if the steering is out of the car then lay it against some heavy steel when you chisel each notch. I prefer to move the metal, rather than file it away.
Tom
Is the part with the notches flat all the way down or is there a bow in it at the lower part. Mine is flat down to about 2/3 the way down then goes back about 3/16 to the bottom. It tends to make the lever snap down. is this the way it is supposed to be. It is fairly substantial so I can't see how or why anyone would have bent it. Can the bottom of the lever that goes into the notches be sharpened a little. |
Gar Williams |
#7 | |
![]() Quote:
