Old 05-20-2013, 07:13 PM   #1
dmaxweb
dmaxweb's Avatar
Default Brake Rod Return Springs - Too Long?
Could someone measure and post the length of orginal wire brake rod return springs. The ones I have measure 5 5/8" tip to tip and I suspect they may be too long. They are causing the front service brake rods to 'bow' away from the frame and the rears away from the radius arms.
dmaxweb is offline   Reply With Quote
Old 05-20-2013, 07:55 PM   #2
Pat Martone
Pat Martone's Avatar
Default Re: Brake Rod Return Springs - Too Long?
I have the same problem and wonder if the bowing rods caused by the too-long wire-type rod return springs are contributing to my brakes being a bit spongy?
I too, welcome advice. Thanks.
Pat Martone is offline   Reply With Quote
Old 05-20-2013, 09:36 PM   #3
QGolden
QGolden's Avatar
I just ordered a set, they should have come in yesterday. I will check and if so, get you a measurment tomorrow.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 05-21-2013, 06:41 AM   #4
QGolden
QGolden's Avatar
Does this help? They are new, not original.
Did you set your service brake rod length proper? 51 7/16 to 51 1/2 center eye to center eye?
Last edited by QGolden; 05-21-2013 at 06:53 AM. Reason: to include flat steel springs.
