Old 08-14-2012, 12:51 PM   #1
len
Default radio polarity
I would like to change my 53 ford 6 volt to negative ground. Would this effect my stock radio. Thanks
len is offline   Reply With Quote
Old 08-14-2012, 02:01 PM   #2
richard crow
Default Re: radio polarity
no as long as it has a vibrater
richard crow is online now   Reply With Quote
Old 08-14-2012, 02:03 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
When I changed over to 12 volts, I was advised that if the radio still had the original type vibrator it is not polarity sensitive and would operate correctly with a voltage reducer. (this turned out to be correct )
If the radio has a modern replacement vibrator it will not work as it is polarity sensitive.
Old 08-14-2012, 11:03 PM   #4
gearhead1952
gearhead1952's Avatar
If you do have a solid state vibrator in it now you can buy one with the opposite polarity.
gearhead1952 is offline   Reply With Quote
