does anyone have some measurements of where to drill the holes in the frame on the driver's side to mount the spare tire arm base? My frame doesn't have any holes. This is a 1930 Briggs Town Sedan.
Look for "dimples". There should be 4.
The pursuit of excellence is healthy and rewarding. The pursuit of perfection is frustrating, neurotic and a terrible waste of time. |
Do a search as Don Turley has posted detailed instructions several times.
Paul in CT |
There are no dimples detectable. Does Don have details regarding location on frame - or just the splash aprons?
Not knowing the history of your car, here is what happened...You may very well have a very early 1930 so the dimples do not show up BUT It was specified on the part releases that the holes for the wheel carrier on the frame side rails were to be drilled in place and that all frames were to be center punched to show the location of the holes.
This area should be between the front brake rod spring bracket and the three holes for the rear motor mount. You just may have a late 1929 frame also. Pluck Last edited by Steve Plucker; 04-23-2012 at 11:35 PM. |
The engine no. was re-stamped as 1304. What's the rest of the number? If that's it, it would be a 1927 block!
#8 | |
![]() Quote:
http://www.abarnyard.com/ |
