Old 03-31-2012, 05:19 PM   #1
Paul from Maine
Paul from Maine's Avatar
Default Timing using NU Rex
I installed the Nu Rex timing indicator. Full retard turned out to be 0 degrees. Full advance is 35 degrees. Half way is 20 degrees. What is the optimum setting for 45 to fifty mph. How much advance is too much? This is a new rebuild and I don't want to pound the babbit out of the bearings.
Paul from Maine is offline   Reply With Quote
Old 03-31-2012, 05:39 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: Timing using NU Rex
If its stock compression, Les Andrews states that each of the 11 notches on the advance lever is good for aprox. 5 mph. I use that as a scale. It works if they arent too worn off. If you have a high cpmpression head you'll have to get that from someone else. Just be sure to back off if or when you hear that ping of pre ignition, that's what kills the pistons!
Good Luck!
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 03-31-2012, 09:22 PM   #3
Jim Parker Toronto
Jim Parker Toronto's Avatar
Why not ask the person who did the rebuild? He has a stake in this too.........
Jim Parker Toronto is offline   Reply With Quote
Old 03-31-2012, 09:42 PM   #4
sphanna
sphanna's Avatar
I wouldn't go more than 26-27* BTDC at speed 45 mph. I use a rule of thumb of .0125 times the engine RPM in thousands. 2200 RPM is about 48 MPH for standard gear ratio and 19 in wheels. 2200 * .0125= 27.5 * Hi comp head maybe slightly less.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
