What holds the condensor into the distributor(besides the srew). Mine feels like something else is holding it in. The truck will run for a while then quit....sometimes I have spark and some times i dont. Does this sound like a bad condensor?
Two screws, one at each end.
Does moving the spark lever make it want to cut out? If so,there could be a broken strand or bare spot on the wire under the breaker plate grounding on the dist hsg.
I was thinking the same as columbiA, plus, if you are using an original popout, it could be a bad wire inside the heavy cable. If you are using a repro ignition switch, it could be contacts that don't make too well.
Moving the lever does not make it cut out. as far as tihe screws go, i only see the one on the tab.....where is the other one?
#6 | |
The picture might answer your question. I tried to link Marco's post, but just the picture shows up. PS ... if you have a "wax like" plug in the hole, it should fetch about $325 on ebay ![]() ![]() |
