Old 07-11-2017, 03:25 PM   #1
zippi
zippi's Avatar
Default *Headlight Adjustment On 37 Pickup*
Take a look at the piccs. My headlight on the passengers side is pointing down much more than the drivers side. I took the light out on the passengers side and did not see any adjustments inside. The only thing I can see is maybe shimming g up under the headlight post that attacheS to the fender. Can someone help out here.
zippi is offline   Reply With Quote
Old 07-11-2017, 03:46 PM   #2
Kerk
Default Re: *Headlight Adjustment On 37 Pickup*
Hi, I believe the adjustment is by swiveling the whole assembly by loosening the Bolt that goes through the mount and aiming the light as needed. Hope this helps. kerk
Kerk is offline   Reply With Quote
Old 07-11-2017, 03:51 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Like Kirk says above, try loosening the big nut on the bottom side of fender support bracket that holds the headlight bucket. When loosened, grab the headlight and re-aim it toward the heavens. Possibly, the pic below will make it clear what is happening. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-11-2017, 04:19 PM   #4
Capt Kirk
Capt Kirk's Avatar
Coop...why are you hiding behind the shower curtain to take that pic?
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 07-11-2017, 04:23 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Wanted to protect ALL viewers' eyeballs from a scary image. DD
T5 W/TORQUE TUBE
Old 07-11-2017, 04:32 PM   #6
zippi
zippi's Avatar
Thanks for the help guys.
