*Headlight Adjustment On 37 Pickup* 2 Attachment(s)
Take a look at the piccs. My headlight on the passengers side is pointing down much more than the drivers side. I took the light out on the passengers side and did not see any adjustments inside. The only thing I can see is maybe shimming g up under the headlight post that attacheS to the fender. Can someone help out here.
Re: *Headlight Adjustment On 37 Pickup* Hi, I believe the adjustment is by swiveling the whole assembly by loosening the Bolt that goes through the mount and aiming the light as needed. Hope this helps. kerk
Re: *Headlight Adjustment On 37 Pickup* Like Kirk says above, try loosening the big nut on the bottom side of fender support bracket that holds the headlight bucket. When loosened, grab the headlight and re-aim it toward the heavens. Possibly, the pic below will make it clear what is happening. DD
http://i.ebayimg.com/images/g/ePQAAM...nt/s-l1600.jpg |
Re: *Headlight Adjustment On 37 Pickup* Coop...why are you hiding behind the shower curtain to take that pic? :)
Re: *Headlight Adjustment On 37 Pickup* Quote:
Re: *Headlight Adjustment On 37 Pickup* Thanks for the help guys.
