Old 05-25-2011, 04:47 PM   #1
fritznbud
fritznbud's Avatar
Default '30-'31 Steering column support mount
fritznbud is offline   Reply With Quote
Old 05-25-2011, 05:08 PM   #2
48Ratfink
48Ratfink's Avatar
Default Re: '30-'31 Steering column support mount
If You do it correctly the first time You will save alot of headache! After 80 years most every possible improvement possible has been done. Let Us know what You decide.
48Ratfink is offline   Reply With Quote
Old 05-25-2011, 05:12 PM   #3
RonC
RonC's Avatar
Mount the support the way the Ford engineers designed it to be mounted. Your way will allow for a greater moment or twist at the connection and will warp your firewall the first time someone pulls on the wheel.
RonC is offline   Reply With Quote
Old 05-25-2011, 05:33 PM   #4
john in illinois
john in illinois's Avatar
i do not understand the problem. If your gas tank/cowl bolts are worn out,put in new bolts. What year is the car? If it is a 30-31 the support bolts right on. If it is a 28-29 you need a 1/4" spacer and need to adapt the spacer to fit the holes in your car and the holes in the support.
John
john in illinois is offline   Reply With Quote
Old 05-25-2011, 06:30 PM   #5
Bill Steiner
I put mine on with no problem. I don't think I understand what problem you are having. Don't understand how you would mount it to the firewall. Bill
Bill Steiner is offline   Reply With Quote
Old 05-25-2011, 07:13 PM   #6
Doug in NJ
Doug in NJ's Avatar
Are you concerned that you may not be able to unscrew the existing bolts because of rust? That can certainly happen. When I took apart my car, it was real tough getting all those bolts out. I ended up wrecking about 4 of the caged nuts on that trim strip, and I had to use a hacksaw or Dremel on a couple of the bolts. Before deciding what to do, you can try to loosen the relevant bolts and see how it goes, before deciding to switch to plan B...
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 05-25-2011, 09:07 PM   #7
48Ratfink
48Ratfink's Avatar
I fully support it being Your car and doing it the way You want,I was just trying to save You more problems. It's not a Ford thing,,Heck I'm a tru blu street rodder at heart!!
Old 05-25-2011, 09:41 PM   #8
JoeWay
JoeWay's Avatar
Originally Posted by fritznbud View Post
...I see no reason not to be able to mount this to the firewall. Looks like it would give good support as it fits midway up on the steering column. Does anyone see any problem with doing it this way? Thanks
You asked for comments; don't complain when you get 'em.
Do I understand correctly that you are thinking of installing the bracket (somehow) near the floor in front of the gas tank? If so, be aware that it will be so close to the frame mounting and so far from the steering wheel that it will not provide anywhere near enough support for the column. If you are that concerned about getting the dash rail bolts out, then leave the project until such time as you can "do it right."
The question is not whether it's a "non-Ford way" but whether it's a way that will work at all.
If I did it right, there should be two pdf files attached showing installation of the bracket.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 05-25-2011, 09:53 PM   #9
Rowdy
Thanks Joe, those PDF's looked good, sure miss the old format. Now I am homesick. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-26-2011, 02:14 AM   #10
Brentwood Bob
nice work Joe. Bob
Brentwood Bob is online now   Reply With Quote
Old 05-26-2011, 05:03 AM   #11
James Rogers
James Rogers's Avatar
Thats the deal, Doug. And there is no plans to tear the car apart...i.e. doing it right. I should have thought out my post before posting at all. It's better to keep my jerry rigging to myself from now on. So on to plan "B" and ill keep my non-Ford way of doing things hush-hush.
Well, you did ask. If you didn't want to hear the truth, why did you ask?
James Rogers is offline   Reply With Quote
