Old 04-14-2025, 12:38 PM   #1
RoadsterFun
RoadsterFun's Avatar
Default Odometer Issue
Hello,
My Speedometer works great, the Odometer has stopped.
What would be my next logical step to correct this issue?
Thanks in advance!
RoadsterFun is offline   Reply With Quote
Old 04-14-2025, 12:44 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Odometer Issue
If you are comfortable taking clocks and watches apart, you could take the cover off it and see if it is something that you can fix. Otherwise send it to a speedometer expert for repair. I would guess a stripped gear.
Old 04-14-2025, 03:01 PM   #3
johnbuckley
johnbuckley's Avatar
often with the odometer it's the" tenths" wheel which gets worn out- poor thing has to turn all the others . As Nkaminar says a quick look won't hurt but I've found professional rebuilds are usually needed for odometers. An excellent article I have on how to rebuild a speedo is " Handouts courtesy of THE BEAVER CHAPTER, MAFCA Portland, Oregon. Article and Sketches by Gordon Fischer. Copyright 6-12-94 " let me know if you can't source a copy.
Old 04-14-2025, 03:49 PM   #4
1928Mik
1928Mik's Avatar
Mine did the same thing. Sent it to Papanick at [email protected]
Came back working and clean. He'll do you right.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible 455 5 speed Restomod
1976 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 04-14-2025, 06:21 PM   #5
papanick
if you need my help email me at [email protected]
papanick is offline   Reply With Quote
Old 04-15-2025, 10:51 AM   #6
RoadsterFun
Thanks all!,
I'm going to take a look inside when opportunity presents.
