The Ford Barn
-   -   Odometer Issue (https://www.fordbarn.com/forum/showthread.php?t=348390)
RoadsterFun 04-14-2025 12:38 PM
Odometer Issue
Hello,
My Speedometer works great, the Odometer has stopped.
What would be my next logical step to correct this issue?
Thanks in advance!
nkaminar 04-14-2025 12:44 PM
Re: Odometer Issue
If you are comfortable taking clocks and watches apart, you could take the cover off it and see if it is something that you can fix. Otherwise send it to a speedometer expert for repair. I would guess a stripped gear.
johnbuckley 04-14-2025 03:01 PM
Re: Odometer Issue
often with the odometer it's the" tenths" wheel which gets worn out- poor thing has to turn all the others . As Nkaminar says a quick look won't hurt but I've found professional rebuilds are usually needed for odometers. An excellent article I have on how to rebuild a speedo is " Handouts courtesy of THE BEAVER CHAPTER, MAFCA Portland, Oregon. Article and Sketches by Gordon Fischer. Copyright 6-12-94 " let me know if you can't source a copy.
1928Mik 04-14-2025 03:49 PM
Re: Odometer Issue
Mine did the same thing. Sent it to Papanick at [email protected]
Came back working and clean. He'll do you right.
papanick 04-14-2025 06:21 PM
Re: Odometer Issue
if you need my help email me at [email protected]
RoadsterFun 04-15-2025 10:51 AM
Re: Odometer Issue
Thanks all!,
I'm going to take a look inside when opportunity presents.
