My '51 Tudor has a new original style wiring harness, have converted to 12 volt neg. ground. Also installing a 1 wire alternator (sorry) and the original regulator has been removed. There are 2 wires which both appear to be grounds, a black/white and a black/red that went to the gen, which now end up grounding to inner fender grounds. Dumb question, but could not both of these leads go onto the same ground bolt on the alternator? I just have to ask, before anything goes live. THANKS.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
I used one of the grounds. Don't apologize for 12V and the alternator. No issues with mine. Check the alignment of the belts, my alternator locating hole that locates on the
alternator bracket (holder) was off 3/16".
Henry Ford designed the flathead without the aid of a computer. |
One is probably a ground and the other one was the field wire . Neither one is needed with the one wire alternator.
