Anybody with a Mitchell overdrive using YAPP Studios Differential vent?
https://www.secretsofspeed.com/diffy-vent Last edited by GPierce; 03-01-2025 at 09:39 AM. |
#2 | |
![]() Quote:
The vent that comes with the overdrive works fine, why not use it?
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup 1931 Coupe 2 Smith Motor Compressors 1951 Ford F1 High Desert Model A's |
#4 | |
![]() Quote:
Tom Endy has an article on this. https://www.santaanitaas.org/wp-cont...ntial-Vent.pdf That's me and my rear end he is referring to. Pictures are of my rear with vent. Last edited by Y-Blockhead; 03-02-2025 at 12:18 PM. |
My version. I decided I wanted to keep the vent vertical. It will make lubing the shaft there a bit more work, but now no drips at the rear wheels.
#7 | |
![]() Quote:
https://www.brattons.com/ORIGINAL-ST...uctinfo/14300/ Was the 45 a pipe fitting? How did you adapt it? |
Install the Endy vent on the passenger side away from the large banjo gear.
Yes, like that but a repro. I don't know what the fitting size is but it was in my box of brass fittings.I got lucky as the threads on the float valve matched the brass fitting. I don't think it is a pipe fitting.
That sounds interesting. Do you have a picture of that?
1/8 npt
1. Model A Zenith FLOAT VALVE is 1/2 20 (NOT pipe thread)
#13 |
I tried drilling a vent through one of the bolts that hold the trumpets on. I put it at the top on the side opposite the crown wheel and the hole facing up. There must be a lot of oil being thrown about in there because it leaked a lot so I made another with a small plastic tube on it (like Mitchell uses on their O/D) and secured the open end up near the spring mount in the cross member I left plenty of slack in it to allow for the movement of the axle. Much better!
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#14 | |
![]() Quote:
