Old 02-17-2025, 01:39 PM   #1
blownford
Default Distributor vacuum brake
What type of glue should I use to attach the leather to the plunger on a crab distributor
blownford is offline   Reply With Quote
Old 02-17-2025, 01:49 PM   #2
Kube
Kube's Avatar
Default Re: Distributor vacuum brake
If you have a correct fitting leather plunger, there is no need for any type of adhesive as the leather is pressed into the steel plunger.
Old 02-18-2025, 03:05 PM   #3
Terry,OH
Terry,OH's Avatar
Rubber cement make sure everything is clean.
Old 02-18-2025, 09:13 PM   #4
mcgarrett
As Kube said - they are pressed into the cavity in the plunger. If that won't work, try some Permatex Black weather strip adhesive.
