Old 01-30-2025, 05:10 PM   #1
SoCal32
Default Best Rubber Dressing for Orig 32 Running Boards
I have a set of original boards in very good shape on my roadster. What's the best dressing to make them look a little better but not turn them brown?
SoCal32 is offline   Reply With Quote
Old 01-30-2025, 06:36 PM   #2
David.kalas87
Default Re: Best Rubber Dressing for Orig 32 Running Boards
I don’t have orig rubbers but I use Adams VRT (vinyl rubber trim). Heavy coat on stained areas and wiped away with the clean side of microfiber gives it a healthy black coat that lasts.
David.kalas87 is offline   Reply With Quote
Old 01-30-2025, 08:24 PM   #3
JayChicago
JayChicago's Avatar
My '40 has original running boards. Have had good experience with Mother's Back to Black. Looks too shiny at first, then in couple hours dries to a natural looking deep black.
Old 01-31-2025, 06:10 AM   #4
KiWinUS
KiWinUS's Avatar
My 36 has original rubbers and have used Kiwi black shoe polish for the last 52 years. Amazing stuff protects. She nes. And fills the little cracks.
Old 01-31-2025, 09:38 AM   #5
glennpm
glennpm's Avatar
Awe, the Burt Munro trick he used on his tyres :-)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 01-31-2025, 09:53 AM   #6
KiWinUS
KiWinUS's Avatar
Absolutely correct. I was going to add that fact. I had met Burt and pushed his Indian and Velocette
Old 01-31-2025, 09:57 AM   #7
glennpm
glennpm's Avatar
Wow, what a treat!
Glenn
Old 01-31-2025, 10:14 AM   #8
TJ
TJ's Avatar
I use Meguires Rubber and Vinyl Cleaner and Conditioner. It does not look greasy and has the correct shine.
Old 01-31-2025, 10:18 AM   #9
KiWinUS
KiWinUS's Avatar
What is “The Correct Shine”.
Old 01-31-2025, 11:28 AM   #10
Ray in La Mesa
We just watched "The World's Fastest Indian" again and enjoyed the trials of Burt Monroe in his quest for speed & his challenges with the beaucracy.
Ray in La Mesa is offline   Reply With Quote
Old 01-31-2025, 01:01 PM   #11
TJ
TJ's Avatar
The correct shine is a non greasy look and appears to look like a new blackwall tire.
Try it and you'll like it.
Old 01-31-2025, 01:17 PM   #12
KiWinUS
KiWinUS's Avatar
Negatory. Kiwi shoe polish has the “Correct Shine” for me.
Cheers.
Old 02-01-2025, 12:32 AM   #13
SoCal32
Thanks to all for the suggestions. I'll try some. Curious on the shoe polish as someone had told me about that but the 32 boards have a "rough" design that I would think would trap a lot of it. 33-40 boards with just long rows would be okay probably.
Old 02-01-2025, 05:35 AM   #14
DavidG
DavidG's Avatar
The pyramid texture of a '32 running board compared to the smooth grooves on a '36 board pretty much rules out shoe polish on the '32 board.
Old 02-03-2025, 11:20 PM   #15
fordor41
fordor41's Avatar
ditto on Kiwi shoe polish
fordor41 is offline   Reply With Quote
Old 02-05-2025, 07:31 AM   #16
glennpm
glennpm's Avatar
Did some searching on HAMB and found a post about using stove polish paste.
https://www.jalopyjournal.com/forum/...#post-15486021
Old 02-05-2025, 07:37 AM   #17
DavidG
DavidG's Avatar
As expected with the pyramids, a real mess.
Old 02-05-2025, 07:47 PM   #18
Jack E/NJ
Jack E/NJ's Avatar
> >The pyramid texture of a '32 running board >> pretty much rules out shoe polish on the '32 board.>>
For this, you need a military grade shoeshine kit. Prolly take a few grueling 12-hrs days to do each side if you're a good & fast. But in the end you'll have a Kiwi correct shoe shine that should last a few weeks.
