The Ford Barn
-   -   Best Rubber Dressing for Orig 32 Running Boards (https://www.fordbarn.com/forum/showthread.php?t=346027)
SoCal32 01-30-2025 05:10 PM
I have a set of original boards in very good shape on my roadster. What's the best dressing to make them look a little better but not turn them brown?
David.kalas87 01-30-2025 06:36 PM
Re: Best Rubber Dressing for Orig 32 Running Boards
I don’t have orig rubbers but I use Adams VRT (vinyl rubber trim). Heavy coat on stained areas and wiped away with the clean side of microfiber gives it a healthy black coat that lasts.
JayChicago 01-30-2025 08:24 PM
My '40 has original running boards. Have had good experience with Mother's Back to Black. Looks too shiny at first, then in couple hours dries to a natural looking deep black.
KiWinUS 01-31-2025 06:10 AM
My 36 has original rubbers and have used Kiwi black shoe polish for the last 52 years. Amazing stuff protects. She nes. And fills the little cracks.
glennpm 01-31-2025 09:38 AM
Awe, the Burt Munro trick he used on his tyres :-)
KiWinUS 01-31-2025 09:53 AM
Absolutely correct. I was going to add that fact. I had met Burt and pushed his Indian and Velocette
glennpm 01-31-2025 09:57 AM
Wow, what a treat!
Glenn
TJ 01-31-2025 10:14 AM
I use Meguires Rubber and Vinyl Cleaner and Conditioner. It does not look greasy and has the correct shine.
KiWinUS 01-31-2025 10:18 AM
What is “The Correct Shine”.
Ray in La Mesa 01-31-2025 11:28 AM
We just watched "The World's Fastest Indian" again and enjoyed the trials of Burt Monroe in his quest for speed & his challenges with the beaucracy.
TJ 01-31-2025 01:01 PM
The correct shine is a non greasy look and appears to look like a new blackwall tire.
Try it and you'll like it.
KiWinUS 01-31-2025 01:17 PM
Negatory. Kiwi shoe polish has the “Correct Shine” for me.
Cheers.
SoCal32 02-01-2025 12:32 AM
Thanks to all for the suggestions. I'll try some. Curious on the shoe polish as someone had told me about that but the 32 boards have a "rough" design that I would think would trap a lot of it. 33-40 boards with just long rows would be okay probably.
DavidG 02-01-2025 05:35 AM
The pyramid texture of a '32 running board compared to the smooth grooves on a '36 board pretty much rules out shoe polish on the '32 board.
fordor41 02-03-2025 11:20 PM
ditto on Kiwi shoe polish
glennpm 02-05-2025 07:31 AM
Did some searching on HAMB and found a post about using stove polish paste.
https://www.jalopyjournal.com/forum/...#post-15486021
DavidG 02-05-2025 07:37 AM
As expected with the pyramids, a real mess.
Jack E/NJ 02-05-2025 07:47 PM
1 Attachment(s)
> >The pyramid texture of a '32 running board >> pretty much rules out shoe polish on the '32 board.>>
For this, you need a military grade shoeshine kit. Prolly take a few grueling 12-hrs days to do each side if you're a good & fast. But in the end you'll have a Kiwi correct shoe shine that should last a few weeks.
.https://www.fordbarn.com/forum/attac...1&d=1738802671
