Old 12-17-2024, 01:19 AM   #1
wga
wga's Avatar
Default Overdrive Cable Clamp on a Shoebox woodie
Ref 49 wagon
Attaching the OD cable with an Addell clamp, which is OK, there is some
movement of the cable inside the clamp. Using the side of the transmission
as a mounting point. Should I be using the smooth end of the cable?
What is the preferred method of mounting and the type of clamp?
Side of the transmission
Any suggestions are welcomed.
thanks
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 12-17-2024, 04:55 AM   #2
Mac VP
Mac VP's Avatar
Default Re: Overdrive Cable Clamp on a Shoebox woodie
I believe the clamp is supposed to fit around the ferrule that you can see further towards the end of the cable. I found some steel clamps that I could modify (grinding the clearance) to fit perfectly around the ferrule and fit in the recessed area around the shifter housing bolt (the one that you are currently using in your photo). I fussed around with my grinder and the dremel to cut the sides of the clamp down and it took a good half hour finessing to get it to fit perfectly but it worked.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 12-18-2024, 02:22 PM   #3
wga
wga's Avatar
Thanks for the help, got 'er done.
