Old 08-20-2024, 11:12 PM   #1
jeepguy1948
Default Pitman Arm?
I made the mistake of posting about this in the For Sale section so I’ll start over here. I need a Pitman arm that clamps on to a square sector shaft (like a Model A uses), is the length of a ‘32 arm, and has a hole in it instead of a permanently attached ball. I could cut up a shortened Model A arm, drill, and taper a hole but I would prefer not to cut up a good one. I don’t know if this is an item that would be “stock” for later (later than a Model A) car/truck or if it would be a custom item. I would like some help figuring out what I actually need and where I can buy one. If somebody has one to sell that would be cool too.
jeepguy1948 is offline   Reply With Quote
Old 08-20-2024, 11:26 PM   #2
big deuce
big deuce's Avatar
Default Re: Pitman Arm?
https://cwmoss.com/products/steering...BoCZHQQAvD_BwE
It's shorter, but still have to eliminate the ball, or modify your drag link to accept the ball.
big deuce is online now   Reply With Quote
Old 08-21-2024, 11:27 AM   #3
jeepguy1948
That’s what I’m using now, the one I would prefer not to cut up.
Old 08-21-2024, 02:37 PM   #4
jeepguy1948
Can somebody tell me if what I am describing even exist’s? And what vehicle it would have been on (I think that the square sector shaft is the biggest issue) so that I can buy one? Or, is there no such thing and I am going to have to make one (which I can do but would rather not if I can avoid it)
Old 08-21-2024, 05:04 PM   #5
alchemy
alchemy's Avatar
No such things from the factory. All the A’s used the ball and socket rod ends. You might ask in the A section if there was a certain variety that had a bolt in ball, but I bet it’s rare.
alchemy is offline   Reply With Quote
Old 08-22-2024, 10:21 AM   #6
TJ
TJ's Avatar
I have four of those type of bolt in ball ends.. Let me know the diameter of the ball and length of the tapered shaft. Got these in a bunch of parts I bought years ago. Three look NOS and there is one used one. Send me a PM.
Old 08-22-2024, 11:00 PM   #7
cas3
I bought the tapered reamer from speedway to fix worn balls with the bolt in type
