Old 07-09-2024, 12:18 PM   #1
drolston
drolston's Avatar
Default Busted Door Glass - How?
When the window was rolled up after the Fourth of July parade, this is what we saw. I happened with the window rolled all the way down. Why? The door was not slammed any harder than the usual firm shove that it takes for the door to latch.
I have purchased an OEM replacement glass for a '41 Mercury from Ebay. It is the narrow door coupe size and looks to have the same measurements as the Ford narrow door coupe. That is, about 17.5" wide by 15.5" tall.
What will I need to bed the front edge chrome strip and the bottom channel?
Any secrets to removing and replacing?
Old 07-09-2024, 12:19 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Busted Door Glass - How?
Old 07-09-2024, 12:27 PM   #3
tubman
tubman's Avatar
My old '36 3-window had a habit of breaking the passenger side window for no reason. After it happened the second time, I replaced the window channels and was careful with their installation. I never had a problem after that. I really don't know what fixed it, but have found that "starting from scratch" sometimes has its advantages.
Old 07-10-2024, 10:58 AM   #4
325w
Does yours have window stops in the bottom? If so be sure you have a rubber pad on the stop.
325w is offline   Reply With Quote
Old 07-10-2024, 11:53 AM   #5
J Franklin
J Franklin's Avatar
I would remove the door panal and see what might be the cause. The channel may stop short of the bottom or some debris might be left in the door. Look for wrong panal fasteners, they could be interfering with the glass.
Old 07-10-2024, 02:38 PM   #6
corvette8n
corvette8n's Avatar
I bought glass setting tape from Bob Drake when I installed a new vent window on my ‘41, it comes in different thickness so you’ll have to measure your channel.
Old 07-10-2024, 10:11 PM   #7
drolston
drolston's Avatar
Thanks,
I am getting NOS door glass and will measure when I get it before ordering the glass setting tape.
Old 07-10-2024, 10:13 PM   #8
drolston
drolston's Avatar
J Franklin and 32 5W,
Good advice, I will want to know the cause before I put in the new glass.
Old 07-11-2024, 12:05 PM   #9
J Franklin
J Franklin's Avatar
Thanks,
If it NOS is it safety glass?
Old 07-11-2024, 06:22 PM   #10
drolston
drolston's Avatar
Good question. I assumed that since the windshields are safety glass that the windows would be also. I will check when it arrives next week.
Old 07-11-2024, 07:21 PM   #11
TonyM
TonyM's Avatar
I am sorry to see. Good luck. I have seen this happen with other vehicles. Puzzling.
TonyM is offline   Reply With Quote
Old 07-13-2024, 11:17 AM   #12
sawzall
sawzall's Avatar
removal of the door glass is a little tricky..
you need to pull the interior door panel (which means pulling the garnish molding around the window. then drop the window down a little to allow you to pull the regulator away from the channel. then rotate the glass back and down to get it OUT the bottom of the door.
as for why it cracked.
it may be a stop, it could be the channel is bad at the bottom
that said. I HOPE the NOS glass you bought is good. I had a PILE of nos glass from the 1950s that I caught at an auction and nearly every piece had fogging / delam.
on my 40 woodie I choose to go with tempered safety class for the side windows.
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/
sawzall is offline   Reply With Quote
Old 07-19-2024, 10:38 PM   #13
nutter_Ford_guy
my 40 Ford broke a side window due to a screw holding the window fuzzy channel coming loose. When driving it moved back and forth enough to crack it almost same as your,
nutter_Ford_guy is offline   Reply With Quote
Old 07-22-2024, 08:12 PM   #14
drolston
drolston's Avatar
It is safety glass. 0.225" thick. Where do I go for bedding for the bottom channel and for the front edge chrome trim?
Old 07-25-2024, 10:34 AM   #15
Als48
Cool Re: Busted Door Glass - How?
Any glass shop should have that bedding tape.
Al Hook
Don't forget, one of the unwritten laws of physics is named after a fellow named Murphy!
Als48 is offline   Reply With Quote
