Old 07-15-2024, 08:07 PM   #1
Joe B.
Joe B.'s Avatar
Default New manufactured coolant pump question
The impeller to housing clearance is .003" on the Ford pump. It's .050" on the new one. See photo. Just wondering if this will affect the flow and how.
thread killer
Joe B. is offline   Reply With Quote
Old 07-15-2024, 09:38 PM   #2
petehoovie
petehoovie's Avatar
Default Re: New manufactured coolant pump question
Old 07-16-2024, 08:42 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
That's a considerable difference between the original and the new one. Closer is certainly better the difference in volume moved between the two might be substantial. Any time I rebuild a water pump the impeller clearance to the housing is no more than .010 to .015.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 07-17-2024, 09:55 AM   #4
19Fordy
19Fordy's Avatar
Joe, contact "Skip" Haney on Fordbarn about rebuilding your pumps using his curved impellor that pumps more water. He also cleans and paints the pumps with a cast iron finish, installs new bearings and seals and mounting gaskets. Well worth the $$. He rebuilt my 8BA pumps a few years ago and they are still working fine.
Old 07-17-2024, 09:29 PM   #5
Joe B.
Joe B.'s Avatar
First, thanks for the responses. .050" seems way excessive, but the pump is in and after a road test, the temps measured with a heat gun at the sensor are what they were previously, (the old pump was dripping at the shaft).
The Bill Hirsch engine paint is a good match and I also did the road draft tube, crossover pipe, gravel shield, new motor mount, and cleaned the manifold heat valve, (it works perfect) while I had her apart. Also, a lot of degreasing.
Happy with the result. I'll keep Skip in mind.
thread killer
Old 07-18-2024, 06:06 AM   #6
flatford8
flatford8's Avatar
Looks like success!…….i like the extra ground straps!…….Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-18-2024, 07:54 AM   #7
Joe B.
Joe B.'s Avatar
Thanks, well you know what the "old timers" say about ground straps on a 6 volt car.
thread killer
Old 07-18-2024, 08:36 AM   #8
Joe B.
Joe B.'s Avatar
Just had a thought. When the gasket and iron thickness at the block are added and factored in, maybe the impeller to housing dimension is a moot point.
thread killer
Old 07-18-2024, 10:37 AM   #9
19Fordy
19Fordy's Avatar
Joe makes a good point.
Here's more info. on flathead water pump flow rate.
https://www.fordbarn.com/forum/showt...9442&showall=1
Old 07-19-2024, 08:27 AM   #10
Joe B.
Joe B.'s Avatar
Thanks for the interesting link.
thread killer
