Old 06-30-2024, 03:21 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default Are 40 drum two peice drums, want to install new wheel cylinders
Need info on how to separate 1940 rear drum from hub to change Wheel cylinders, thanks in advance.
Bruce in southern OH is offline   Reply With Quote
Old 06-30-2024, 03:32 PM   #2
meric42
meric42's Avatar
Default Re: Are 40 drum two peice drums, want to install new wheel cylinders
You will need to remove the drum and hub as they are held together by the wheel studs and do not separate to remove from the car. The rear ones are the hardest as you need a special puller to remove the hub from the axle taper, the nut is tightened to 200 Foot-pounds when reassembled.
This is the hub puller I and others use: https://vintageprecision.com/product...ers/index.html
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 06-30-2024, 03:46 PM   #3
Thank you
Old 06-30-2024, 05:48 PM   #4
19Fordy
19Fordy's Avatar
Bruce: Be sure and use the hub puller mentioned above so you don't damage your axle or drum. DO NOT USE THE OLD STYLE 3 LEGGED PULLER THAT BOLTS TO THE LUG NUT STUDS.
Old 06-30-2024, 06:33 PM   #5
Thank you 19Forty and Meric42, now anyone have one they want to sell, here in the states rather than have another tool you use every 10 years. I have asked everyone in my area this afternoon and several suggested loosen nut and drive around and it will come loose. Well I cannot drive at this time because I have brake lines, master cylinder removed. I will ask in the Wanted Section, was hoping to have done this week. thanks again
Old 07-01-2024, 03:51 AM   #6
aussie merc
aussie merc's Avatar
original ford style is known as drum on hub and need to be removed as one item . The modern replacements[ boiling bros /speedway] are drum over hub and can be removed with out the hub . Tools are required so dont try to shortcut you can do some real damage search the posts on here and dont be frightened to ask questions there is plenty of advise and help available
aussie merc is offline   Reply With Quote
Old 07-01-2024, 05:51 AM   #7
HDowse
HDowse's Avatar
Bruce, check on the Early V8 club site to find a club near you. If there’s a contact number call and ask about a puller. BTW, if you buy the suggested puller, you will find that you use it fairly frequently for servicing the rear brakes. Plus, you'll have many friends who will want to borrow it!
HDowse is offline   Reply With Quote
