Old 04-23-2024, 04:58 AM   #1
BlueNotes
Default KR Wilson engine lifting bracket
I recently scored a repro KRW engine lifting bracket but the 2 knurled pins are missing. Can anyone advise the measures (or a simple drawing) for the pin so I can make them?
BlueNotes is offline   Reply With Quote
Old 04-23-2024, 08:20 AM   #2
hop up
hop up's Avatar
Default Re: KR Wilson engine lifting bracket
The pins are .500 x 2.375 that fit into the bracket and have a .750 x .500 length head. The over all length is 2.875 including the head .
A picture and let me know if I can help as I have a machine shop
Wanted Ford oiler oil cans Thanks
hop up is offline   Reply With Quote
Old 04-23-2024, 10:47 AM   #3
petehoovie
petehoovie's Avatar
Old 04-23-2024, 10:47 AM   #4
petehoovie
petehoovie's Avatar
Old 04-23-2024, 11:11 AM   #5
BlueNotes
Thank you very much @hop up! That's all I need to make them.
Old 04-23-2024, 02:17 PM   #6
GB SISSON
GB SISSON's Avatar
Could somebody post a photo of one of these in action? I'm not seeing how it works.
Old 04-23-2024, 02:45 PM   #7
BlueNotes
It fits in the valley and the two pins drop inside the heat risers.
Old 04-23-2024, 02:58 PM   #8
petehoovie
petehoovie's Avatar
Old 04-23-2024, 03:15 PM   #9
Tim Ayers
Yep. I believe you can flip it 180 degrees to have the motor angled either forward or back, right? The offset changes the angel the motor will hang.
Tim Ayers is online now   Reply With Quote
Old 04-23-2024, 04:38 PM   #10
Ronnieroadster
Ronnieroadster's Avatar
Tim from my experience using the KR Wilson one I have if its turned around the lifting bracket will not sit flat on the inside surface of the valve chamber.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 04-23-2024, 05:29 PM   #11
GB SISSON
GB SISSON's Avatar
Perhaps in the other position it's for if a transmission is attached?
Old 04-23-2024, 10:35 PM   #12
outlaw
I made a adjustable lifting plate for my flatheads.
outlaw is offline   Reply With Quote
Old 04-23-2024, 11:24 PM   #13
mercman from oz
mercman from oz's Avatar
adjustable lifting plate - outlaw
Old 04-24-2024, 07:04 AM   #14
rockfla
rockfla's Avatar
I got this one off ebay and works great.
Old 04-24-2024, 07:24 AM   #15
Tim Ayers
Ronnieroadster
Ahh. Interesting. I don't own one, but I've thought that's how it worked. Thanks for setting me straight. I've been on the hunt for one for years. They've all seem to have disappeared.
Old 04-24-2024, 11:04 AM   #16
petehoovie
petehoovie's Avatar
