Old 01-07-2024, 03:33 PM   #1
midgetracer
midgetracer's Avatar
Default Aristocrat dash??
I acquired this steel dash panel in a recent purchase. It had two Rex-A-Co gauges with it (an oil pressure 1-10 psi, and a temperature gauge with the tube cut off). Is this a cheap version of the Aristocrat panel or some knock off? Does it have any real value and can it be made to look like a panel with the engraved center? It does perfectly fit over a round speedometer gauge panel.
Thanks for any help.
midgetracer is offline   Reply With Quote
Old 01-07-2024, 04:18 PM   #2
ronn
Default Re: Aristocrat dash??
midget, I have seen the one you are showing, selling in the 250-300. range.
The actual Dun dashes, well one hit 690. on the bay a few weeks back. Apples and oranges in appearance.
Brad from Germany is the guy to ask. He has several of them.
wonder if a stencil is available to insert on yours?
Old 01-07-2024, 07:18 PM   #3
Brad in Germany
Brad in Germany's Avatar
In the absence of the cross hatch background pattern on the face, you could woodgrain (in circassion walnut finish) the insert area like this original one with an oval speedometer opening. Note the original Dunn gauges:
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 01-07-2024, 10:01 PM   #4
Technite73
Here is an original Aristocrat dash with original Dunn gauges.
The jewel dash light is another aftermarket accessory.
Technite73 is offline   Reply With Quote
Old 01-08-2024, 06:56 AM   #5
ronn
so nobody makes contact decals that mirror the original cross hatching?
not a fan of the walnut finish
Old 01-08-2024, 10:19 AM   #6
jayg48anglia
jayg48anglia's Avatar
Try Pfitzinger Graphics,Fenton, MO. 636.349.3344. www.PfitzingerGraphics.com
jayg48anglia is offline   Reply With Quote
Old 01-08-2024, 10:39 AM   #7
Ray in La Mesa
X2 on Pfitzinger Graphics. They put out a fantastic faceplate cover!
Ray in La Mesa is offline   Reply With Quote
Old 01-08-2024, 10:57 AM   #8
ronn
thank you for the info Jay!
