Old 10-06-2012, 04:45 PM   #1
lodown2003
Default 1936 coupe trunk lid hinge question
on the placement of trunk hinge to the body does anyone out there have any images of location.cant remember if that part goes behind or in front of that plate. hope someone out there can help a frusterated guy out, thanks. non rumble.
lodown2003 is offline   Reply With Quote
Old 10-06-2012, 06:59 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 coupe trunk lid hinge question
The hinge block goes on top of the horizontal "c" channel bracket.There should be 4 slotted holes on each so you can make adjustments.
Old 10-07-2012, 04:22 PM   #3
Randy in ca
Randy in ca's Avatar
Here's a couple of pictures I took when disassembling a 1935, which I assume is pretty much the same setup on a 36. Note that the bolts which attach the bracket on the front have already been removed. Hope this helps some, good luck.
Randy in ca is offline   Reply With Quote
Old 10-17-2023, 12:37 PM   #4
SSRMORSE
I have a 1935 Ford coupe and the trunk hinges don’t allow the trunk to close all the way? The 35 hinges say 713570 on them. The car had been changed over to a rumble seat and I am putting it back the the original. Any information on installing a 1935 couple trunk lid or ideals would be helpful. Thank you.
SSRMORSE is offline   Reply With Quote
Old 10-17-2023, 02:37 PM   #5
petehoovie
petehoovie's Avatar
Old 10-17-2023, 02:51 PM   #6
Karl Wescott
Karl Wescott's Avatar
SSRMORSE:
Both 1933-34 and 1935-36 Hinge arms will be marked 713570. 1933-34 will have a prefix of 40, 1935-36 of 48. Post a photo of the hinge you have (or email to me at [email protected] and I will repost) and we will try make sure its a 1935-36.
Karl Wescott is offline   Reply With Quote
Old 10-17-2023, 03:59 PM   #7
TJ
TJ's Avatar
Have you replaced the metal lip at the bottom of the opening. On the original conversion that lip has probably been cut out.
