The Ford Barn
-   -   1936 coupe trunk lid hinge question (https://www.fordbarn.com/forum/showthread.php?t=85308)
lodown2003 10-06-2012 04:45 PM
on the placement of trunk hinge to the body does anyone out there have any images of location.cant remember if that part goes behind or in front of that plate. hope someone out there can help a frusterated guy out, thanks. non rumble.
deuce lover 10-06-2012 06:59 PM
Re: 1936 coupe trunk lid hinge question
The hinge block goes on top of the horizontal "c" channel bracket.There should be 4 slotted holes on each so you can make adjustments.
Randy in ca 10-07-2012 04:22 PM
2 Attachment(s)
Here's a couple of pictures I took when disassembling a 1935, which I assume is pretty much the same setup on a 36. Note that the bolts which attach the bracket on the front have already been removed. Hope this helps some, good luck.
SSRMORSE 10-17-2023 12:37 PM
I have a 1935 Ford coupe and the trunk hinges don’t allow the trunk to close all the way? The 35 hinges say 713570 on them. The car had been changed over to a rumble seat and I am putting it back the the original. Any information on installing a 1935 couple trunk lid or ideals would be helpful. Thank you.
petehoovie 10-17-2023 02:37 PM
https://www.fordbarn.com/forum/attac...7&d=1349644861
https://www.fordbarn.com/forum/attac...8&d=1349644861
Karl Wescott 10-17-2023 02:51 PM
SSRMORSE:
Both 1933-34 and 1935-36 Hinge arms will be marked 713570. 1933-34 will have a prefix of 40, 1935-36 of 48. Post a photo of the hinge you have (or email to me at [email protected] and I will repost) and we will try make sure its a 1935-36.
TJ 10-17-2023 03:59 PM
Have you replaced the metal lip at the bottom of the opening. On the original conversion that lip has probably been cut out.
