Old 04-12-2023, 11:44 AM   #1
Ziggster
Default Another Question - C59A block coolant passage
I just noticed this threaded passage in the block just behind the water pump mating surface as I was prepping it for paint. In all the years I’ve now had this engine, I don’t think I ever noticed them. Going through the flathead books I have, I see no mention of them. The one book by Mike Bishop & Vern Tardel show a block being assembled with the port blocked off, while I. The book by Tony Thacker & Mike Hernan the block used in their assembly pics has no port. So, the question is what were these ports for? Will now need to get more 1/4” NPT brass plugs.
File Type: jpg 56DC7877-1525-47AB-A0C2-EA9FC6340883.jpg (30.3 KB, 124 views)
Ziggster is offline   Reply With Quote
Old 04-12-2023, 12:24 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Another Question - C59A block coolant passage
Old 04-12-2023, 12:28 PM   #3
flatjack9
flatjack9's Avatar
Simply a drain plug. Not uncommon.
Old 04-12-2023, 04:05 PM   #4
Ziggster
Thanks. Just curious. Will plug them up.
Old 04-13-2023, 11:24 AM   #5
rotorwrench
rotorwrench's Avatar
The Canadian blocks were all cast across the river in Windsor Ontario and they did things a bit different than the Rouge on the other side. Ford did various things for block drains over the years so nothing surprises me much anymore.
Old 04-13-2023, 10:46 PM   #6
outlaw
My block did not have them, so I drilled & tapped it on both sides there for drain petcocks.
outlaw is offline   Reply With Quote
Old 04-14-2023, 05:51 AM   #7
Flathead Fever
Flathead Fever's Avatar
I have vintage brass petcocks in all of mine. They work great for draining every last drop out of there when I change the coolant, like you're supposed to do every two-years.
