Old 05-22-2023, 09:35 PM   #1
Safari bob
Default Clutch disk - 4 speed transmission
I have a 4 speed transmission that I believe started it life in a ford 150 truck. It was adapted to fit a Model A. I am searching for a part number for the clutch disc. The hub of the Model A clutch disc is too large. Any help would be very much appreciated.
Safari bob is offline   Reply With Quote
Old 05-22-2023, 11:20 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Clutch disk - 4 speed transmission
Find the disk for that year transmission.
Old 05-23-2023, 07:52 AM   #3
kenparker0703
The disc that fits the 1984 - 1987 F150 truck will not work in the Model A adaption. Disc to large diameter.
I ordered and received one that will work last month. It is installed now.
Part number D923. Ordered thru Auto Zone. Clutch disc fits the 1969 Ford Falcon with a 200 cu in engine.
kenparker0703 is offline   Reply With Quote
Old 05-23-2023, 04:45 PM   #4
Safari bob
The F 150's had n 11" disc where mine is 9". Thanks for responding.
Old 05-23-2023, 04:47 PM   #5
Safari bob
I am off too Auto Zone to place an order. I assume you have the converted F 150 Transmission as I do. Easy to drive with it but a little tough on some hills.
Thanks for your response.
Bob
Old 05-23-2023, 05:28 PM   #6
AL in NY
AL in NY's Avatar
Go to your locate parts store and get a clutch out of a 1986 T-Bird with the 4 cylinder turbo engine. The clutch is 9" with the correct 1 1/16" x 10 spline.
AL in NY
AL in NY is offline   Reply With Quote
Old 05-26-2023, 03:04 PM   #7
Safari bob
Thank You for your response. I have ordered that part.
Bob
Old 05-26-2023, 04:23 PM   #8
Gene F
Gene F's Avatar
This is great information guys. My local NAPA store has one counter clerk that knows about parts. I have a streetrod, that I did not engineer. The original builder died. Sometimes finding the right part is like a treasure hunt. I have helped myself more than anything, or any one else. That one good counter person is not too bad, but I have to point him in a direction.
AutoZone is a complete joke as far as parts knowledge. Advance is not too bad if I get one guy. He does at least try.
