any of you guys tried the Edelbrock 94 carb? or have any input? i need to purchase 2 carbs and was woandering. how about speedways 9 super 7 carbs?.......any input would be great. thank you
There was a thread started about 2 weeks ago that would probably answer 98% of your questions.
https://www.fordbarn.com/forum/showthread.php?t=31398
Don't never get rid of nuthin! |
thank you Pete
The Eelebrock carb is a 500cfm unit,and you didn't give us any information on the engine mods. The 390 is avery good street carb, but the WCFB is probably the best choice, if you can find one is good working order.
I believe the 94 to be the better of the two in original form. I would opt for the Edelbrock, I have heard of problems with new 9 super 7's
Thanks Mike Goodman.
"I ain't no mechanic, my posts should make that obvious, I'm jus doin my best with what I got." |
thanks guys.......ron, the carbs will be going on a 8EA with a mercery crank and a mild street cam. the intake is a fenton for 2 carbs. the engine is fresh and i have not gotten to the point to fire it up yet. i am thinking edelbrock after what i have read with the help from pete on the posts 3 weeks ago......thanks so much guys with your help. i am fixing up an old F1 pickup that was rotting in a field, she is looking pretty good so far, and i might get her on the road by this fall.
#8 | |
![]() Quote:
#1159 around $20 Last edited by 1oldtimer; 03-27-2011 at 05:17 PM. |
Kendall,
There are lots of challenges with the 9 super 7. The new Edelbrock carbs are listed at $349 each and present a throttle hook up problem that is fixable to be sure but that adds $$$. Think about a pair of real 94's rebuilt the way you want for just a bit more than one Edelbrock newbe. The Edels will need to be setup and once you touch a screw on either one you own them period. Charlie ny [email protected] |
