Old 03-08-2021, 11:36 AM   #1
California Charlie
California Charlie's Avatar
Default No Foot Starter
Has anyone installed a 6 volt 3 terminal solenoid on a Model A Starter Motor to eliminate the manual foot starter? Is there a diagram as to how this is done with wiring etc.
Thanks to all who respond to my question.
California Charlie is offline   Reply With Quote
Old 03-08-2021, 12:01 PM   #2
alexiskai
alexiskai's Avatar
Default Re: No Foot Starter
Here's one for Model T, probably works the same.
Old 03-08-2021, 01:17 PM   #3
California Charlie
Thanks very much, that diagram does help.
Old 03-08-2021, 02:43 PM   #4
Ruth
Don't you need to lock the starter switch in the closed position or something also?
Ruth
Old 03-08-2021, 02:47 PM   #5
Bill Cilker
Bill Cilker's Avatar
I had the solenoid / key setup on a sedan when I purchased it. I had to reach through the steering wheel with my left hand to turn the key while I pulled the choke with my right. I quickly took it off and went back to original. It was much easier.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, & 160B
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 03-08-2021, 02:56 PM   #6
alexiskai
alexiskai's Avatar
There's a couple ways to do it, this thread covered it pretty well:
https://www.fordbarn.com/forum/showthread.php?t=148555
Old 03-08-2021, 03:27 PM   #7
Ruth
YIKES!! That diagram in post #3 of the link above is WRONG. The second small terminal (if the solenoid has one, usually only seen on 12v solenoids) should go to the ignition coil, not GROUND. They are even usually marked with an "I", for ignition.
Ruth
Old 03-08-2021, 03:31 PM   #8
alexiskai
alexiskai's Avatar
Seems reasonable (the solenoid body itself is usually the ground), but why does it need a wire to the coil?
Old 03-08-2021, 04:01 PM   #9
MrBruce
MrBruce's Avatar
I'm making some up with Solenoid 240-01006 which has a button on it so if your under the hood you can just hit the button in the solenoid and not go to the inside of the car and hit the button. You can use the starter switch, but have to push the copper strip down with a bolt. I have it all worked out and working.
MrBruce is offline   Reply With Quote
Old 03-08-2021, 08:41 PM   #10
Ruth
On 12v systems it will give a full 12v to the coil for starting, bypassing to ballast resister, which reduces the voltage to ~9v. Then when you release to starter switch, 9v is supplied to the coil as the full 12v is not needed once the engine starts.
6v solenoids do not have the second small terminal nor a ballast resistor.
If it was hooked up like the diagram in the link, you would definitely lose some smoke out of your wires.
File Type: jpg Screen Shot 2021-03-08 at 5.44.01 PM.jpg (12.3 KB, 87 views)
Ruth
Old 03-08-2021, 08:57 PM   #11
Bob C
Not necessarily, depends on how the solenoid is wired internally.
Old 03-08-2021, 08:59 PM   #12
Ruth
I seen a "No-Foot-Starter" advertise in latest Model "A" News.
Ruth
Old 03-08-2021, 11:05 PM   #13
Bill G
Bill G's Avatar
I have one of those and it was an easy install and I like it a lot. More importantly, my wife likes it!
Old 03-08-2021, 11:24 PM   #14
Ruth
Sure solenoids are used in many applications. But I would have to say that 100% of the solenoids I have seen in automotive starter circuits are as I described.
Ruth
Old 03-09-2021, 12:45 AM   #15
CarlG
CarlG's Avatar
I started doing the solenoid starter thing back in the late '50s on my '31 AA. I didn't have books, internet, or whatever, I just figured out how to do it myself.
That carried thru to today where I have a key start switch in my '31 pickup.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-09-2021, 12:32 PM   #16
California Charlie
Smile Re: No Foot Starter
Happy Camper here.
Thanks to all who responded to my post. I was able to use the information to successfully install a 6 volt solenoid on my Model A Ford Starter Motor.
It works perfectly!
Thanks again!
Old 03-09-2021, 03:47 PM   #17
woofa.express
woofa.express's Avatar
Thankyou all for that information. I really don’t wish to modernise my A but I’m not pedantic about it either. It’s just I continually get my shoe caught between the clutch and hand break, (my A’s are right hand drive). Where have you all placed the starter button or have you gone for an ignition/starter key?
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 03-09-2021, 04:45 PM   #18
CarlG
CarlG's Avatar
Originally Posted by CarlG View Post
... I have a key start switch in my '31 pickup.
Alaskan A's
Old 03-09-2021, 05:31 PM   #19
Ed in Maine
Guys, the foot starter switch is part of the whole Model A experience. It keeps all others guessing what the driver is doing leaning back and stretching out while the motor starts. It is one of the the only cars left on the road where your foot is turning on a 50 amp current to start the engine. I also own 1914 Model T and I can assure you that when that starter switch first appeared, it put smiles on the faces of a lot of people, especially in the winter time!! Ed
Old 03-09-2021, 06:13 PM   #20
woofa.express
Hi Ed. I wouldn't change mine but for the fact I continually get my foot caught between the handbrake and clutch. I would suspect the LHD cars have considerably more room on the floor and confinement is not a problem.
I know many things,
